coolmom42's avatar
coolmom42
Oct 26, 2020
questions.... I have them.. :D
1) the fresh water tank fill on my motorhome is the kind where you have to hook up a hose and have pressure on it, to fill, just like the "city water". I would prefer to have a gravity fill so water can be added from a jug, or from a hose, using this adapter that I already have. I also really dislike messing around with screwing the hose on.
Question 1: How big a deal would it be to change out that opening and is it something a person with a few skills could do herself?
I'm also planning to winterize by blowing out the lines, rather than pink stuff (except the traps, of course.) I may go back and forth a few times a year doing this, so it seems less hassle than removing all the stuff in the storage space, taking off a panel, using the pump, and then reversing the process before very long. I have a small compressor and hose.
Question 2: Is this the fitting I need?
Question 3: Are there any particular pitfalls to winterizing using compressed air? I've been googling around and reading here.
