Nov-19-2016 02:10 PM
Nov-30-2016 02:04 PM
Nov-29-2016 08:04 AM
Nov-28-2016 02:18 PM
Nov-28-2016 11:45 AM
Nov-28-2016 10:11 AM
Nov-28-2016 09:13 AM
Nov-28-2016 08:30 AM
Nov-28-2016 08:18 AM
Nov-28-2016 07:48 AM
Nov-28-2016 07:45 AM
time2roll wrote:
Yes it will overflow as the air bubble expands due to rise in temperature.
All you can do is attempt to catch the overflow. When the thermostat opens the radiator will seem to go empty. Keep topping off for 5 to 10 additional minutes.
I assume you have a coolant recovery bottle. This will chase any remaining air out of the system during the first few heating and cooling cycles.
I have always thought about drilling a 1/16" or 1/8" hole in the flange but have never tried it. Can't see that it would hurt much. Could go down and ask for a premium thermostat and see if it has the release hole. Or possibly remove the thermostat during the initial fill to that level. Still need to observe the thermostat open and verify the level before you roll.
No idea why it shut off.
Did you have the old thermostat in during chem clean? Probably had the release valve. Dig it out of the trash and inspect.
Nov-28-2016 07:35 AM
Nov-28-2016 07:23 AM
Nov-27-2016 05:48 PM
Nov-27-2016 05:17 PM
MarkLDN wrote:Classic air pocket in cooling system. Need to top off again with 50/50 mix. Let it idle until you see the coolant moving through the radiator.
Right. Something has gone wrong.
I put a final topoff in the radiator, capped it and warmed up the engine. I then took it for a slow 20km/hr drive around the block and the engine died on me after about 300 meters. It restarted and after getting it back to the hose the temp gauge was past the midpoint and steam was coming out of the hood. It was coming from the radiator.
