swimmer_spe
Jun 19, 2020Explorer
Bobbo wrote:Boon Docker wrote:
Set your multimeter to ohms. Ground one probe to the frame then touch the other probe to each wire separately.
A reading of zero to 1 ohm means that wire is negative.
Be sure that no wires are connected to the battery's positive terminal. Touch a hot wire like this and you will damage the meter.
I know how to use one. I was hoping that it would have been simple as white is always ... The idea of the ohm test on the frame and wires will help.
