powellmj's avatar
powellmj
Sep 16, 2019
Refrigerator Outside Vents
I have a Wolfpack 325 pack 13. The cabinets over fridge held a lot of heat and the freezer was just ok. Noticed a wasp flying around the external vents and thought I better check for nest. Pulled the top vent cover and was surprised to see that the wall covering came up over the fridge heat dissipater and there was a board across the top blocking airflow (pictures explain better) anyway there was only about a 3 inch gap for the heat to exhaust. I made some modifications and Wow, the difference was immediate. The aux fan had even shut off before I had things cleaned up and back together. It's worth a look to pop off that top vent cover and check.
https://ibb.co/k5fgd1c
https://ibb.co/qyCLYhK
