Wranglerx369's avatar
Wranglerx369
Removing/eliminating front window in Truck Camper
Has anyone out there ever completely removed the front window on there camper or trailer.
My 2003 Lance has a standard factory installed window in the front. There are a few small blister starting around the edge of the window under the fiberglass. No visible leaks inside, but don't want any.
I was thinking about completely removing the window and then covering entire front flat portion with a piece of aluminum diamond plate. - covering the removed window hole and the front of the camper. 90" x 22". Then making a custom cover/ headboard to cover the interior.
Any thoughts on this idea.
Thanks, Dan
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
