- KpackpackkelleyExplorer IIWhat type of gen dies it have. Gen should be setting in its own tray should have 4 bolts holding it. I wouldn't think it would be you rubber isolator bolts. Look under trailer where the gen is.
- D_E_BishopExplorerPatrick,
If you continue to have a problem, call Red Bay and ask them how it was installed. They made the coach and they are very proud of what they build. I believe the owner is named Bob Tiffin and he will talk to you if you ask. He has taken the door off his office to show he really has an open door policy. Just because you have an older rig doesn't mean they have washed their hands of it. - Son_of_NorwayExplorerThere should be 4 bolts on rubber mounts, the wiring, the fuel line and the exhaust. I have used a wooden ramp to slide them out in the past. What kind of unit is it and what's the problem? Many repairs can be done with the genny in place. Good luck with your repairs. By the way, welcome to the Forums!
Miles - Passin_ThruExplorerYou might search around the site as somone had a question before but I'm not sure without a sliding tray. I suppose its just bolted to Lord mounts.
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
