psa0298
Aug 09, 2013Explorer
Repair or replace A/C
Just a follow up to this post:
http://www.rv.net/forums/index.cfm/fuseaction/thread/tid/27143110.cfm
I swapped all condensers and relay from my working a/c in the rear to the nonworking unit in the front. The front still did not work and the back did work (with the swapped parts from the front) so the problem was not with the condesnsers/relay. Checked all conections...no damaged/loose wiring. I think it is time for a new a/c unit. Thoughts? Suggestions? Thanks again!!!
