doughere
Sep 27, 2023Explorer
Replace Girard tankless how water heater
I just bought a Cougar 5th wheel with a Girard tankless how water heater. What a joke! Unit will supply hot water heater endlessly, but not intermittently. This means any time you want hot water, you waste about a quart until you get hot water. Showering can not be a sub-shower, as you will be hit with a shot of cold water each time you turn the shower back on.
There appears to be enough room to put a conventional RV how water heater where this piece of c$&% is. Has anyone tried (hopefully succeeded) to do this, how bad was it.
Thanks,
Doug
Thanks,
Doug
