buylow12's avatar
buylow12
Replacing Storage Locks
Hello All,
I'm getting ready to replace the locks on my fifth wheel storage compartments. However the previous owner had over tightened several them, probably in a vain attempt to keep them from turning. This has resulted in the door being compressed there and of course, if you can spin the entire lock, you might as well not have a lock at all.
So I was thinking of just trying to find some large washers and putting one on each side of the lock. That should spread the pressure and hopefully keep it from compressing more. However I'm not sure if that would solve the other problem of being able to spin the entire lock. Also the current locks are 7/8 and it would be tight if not impossible to fit two washers on the barrel. I'm thinking maybe I should go up a size.
Anyone else have this issue? Is there a better way to handle the locks turning like that? Any other tips or advice when it comes to changing out the locks would be appreciated too ;)
Thanks,
Tim Czarkowski
TotalTravelers.com
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
