Carrera_man
Mar 19, 2015Explorer
Well I believe I found the problem. As some of you have suggested the problem is in the seven way plug. Checked the terminals, the right light was getting 4 volts. Sprayed the plug with DeOxIt electrical contact cleaner. Rear light got very dim, voltage went down to 2 volts. Rapped the plug a bunch of times against the frame, light went out, voltage went to zero. This plug is a molded plug onto the wire so that's why I couldn't take it apart. I suspect moisture get into it one way or another creating corrosion. We had a tough winter here this past year and it pretty much stayed below freezing for about 8 weeks. When our thaw happened last week is when the light came on. I'll replace the plug in a week or two just for the heck of it and cut the old one apart to see if I could find what problem was. A big thank you to everyone for taking the time to give me your opinion!
