mena661's avatar
mena661
Rogue 20A MPPT Controller Question
Maybe Marc will chime in but maybe this question is generic enough that others might answer. I was perusing the Rogue 20A manual and saw the 320W limit for 12V systems. I'm wanting to put two 150W panels in series to up the volts and reduce current in an attempt to be able to use more panels on the controller at a later date. If my total amps is well under 20, can I go beyond the 320W max for the controller?
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
