joraz's avatar
joraz
Roof A/C Issue
Class C with a 13.5 Dometic (Model Number: 520316.506E) year 2009
My rig is parked at the house in the hot Arizona sun. The A/C works fine for most of the day but when the ambient temp hits 104 or so the compressor shuts down and the fan blows hot air.
The A/C has had little use over the years. I cleaned both the evaporator and condenser coils although both were already very clean.
The unit is draining as it should and the interior filters are clean.
I did a voltage check over the day yesterday and have eliminated low voltage as the problem.
I have been advised on another forum that the issue could be the overload protector (thermal switch) which is designed to shut down the compressor when it's too hot. So I figured I would just replace it. Problem is that it looks to be internal to the compressor.
Any ideas? Thanks.
jor
Compressor Photos
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
