MrWizard wrote:
That generator is so old
There is no EVR
With either a permanent magnet field, or with diode and capacitor in the circuit feels windings
If you but a scope on it, you would see a big spike
It's find for motors, or old heavy transformer battery chargers, but modern digital electronics refuse to operate on something like that
You're absolutely correct on the age of it! But it's still so pretty with it's bright red paint on it's nearly all-steel case and hardly any scratches, and it's so quiet (54dB all the time), and it's so stingy on gas, and it starts right up on ethanol gas even after long storage periods . It's kind of a legend in the Honda world for those who know about it and/or have ever owned one ... it was considered a very high end superb piece of equipment way back when in it's day. You probably know how it goes for those of us with that "let's see just how long we can keep the old girl running" fetish!
That being said ... doesn't my $$$$ built-in non-inverter Onan have almost the same (ancient) output regulation/clean-up technology as the 25 year old non-inverter Honda? The Norcold has no problem running off the Onan.
CA Traveler ... thank's much for your suggestion above on grounding the Honda to the motorhome. That just must might be the problem! I guess I just have to run a small wire from the Honda's stainless steel grounding screw over under a screw head on the E450's frame to complete this ground?? I'd like to be able to count on the little Honda for a backup - instead of the big Onan - if the propane system should ever fail while we're out and about drycamping.
I'm also wondering if a simple 120V-to-120V inline isolation transformer plugged in between the Honda and the motorhome's shore cable wouldn't fool the Norcold into running just fine off the Honda ... if CA Traveler's grounding suggestion doesn't do it?
