โMay-24-2018 01:46 PM
โMay-26-2018 05:31 PM
โMay-26-2018 08:32 AM
โMay-25-2018 04:01 PM
โMay-25-2018 01:05 PM
BradW wrote:
I spoke with a very helpful Lance rep today. He told me that the only reasonable way to get electric strip heat in the A/C unit was to order the camper without any A/C and buy the unit I wanted separately and have the dealer or myself install it.
He also confirmed the camper has the pre-cut hole for the A/C and it is pre wired with 120V.
That works for me and that is what we will do.
Thanks for the responses,
BradW
โMay-25-2018 10:29 AM
โMay-25-2018 06:08 AM
โMay-25-2018 03:59 AM
dougrainer wrote:
They run a standard 7 to 8 wire harness from the Roof AC to the wall tstat. They only use 5/6 of those wires. So if you add the Heat Strip, you have the extra wire to connect. The NORMAL wall RVP tstat will NOT have the Heat Strip on it. They install the model tstat that has GAS heat. You would have to purchase the wall tstat that has the dual switch--Gas and electric(HS). Doug
PS, you understand that the optional Heat Strip does NOT heat the RV. It just takes the chill out. It is only a 5600 BTU heater.
โMay-24-2018 03:29 PM
BradW wrote:Normal? What make and model air conditioner and heat do you have?
Do RV manufacturers normally run the heat wire to the wall thermostat even if the A/C unit does not have heat?
โMay-24-2018 02:38 PM
โMay-24-2018 02:04 PM
โMay-24-2018 02:00 PM
