โOct-25-2019 12:41 PM
โMay-06-2020 06:26 AM
wa8xym wrote:
Drain anything in the fresh water tank (Not easy on my rig)
โMay-06-2020 04:22 AM
โMay-06-2020 12:09 AM
โOct-29-2019 04:53 AM
DrewE wrote:suprz wrote:DrewE wrote:
A gallon down each drain? Exactly how large are the P traps in your RV?
A cup or so is sufficient in nearly all cases.
Yes, cause there's always something left in the holding tanks too, no matter how long you drain them for.
At least on my motorhome, there is precious little left in the holding tanks after letting them drain for awhile provided the RV is level or tilted towards the drain (driver's) side. The outlet is molded in even with the bottom of the tanks, and so they would drain as fully as a bathtub. The teeny bit of water left in the holding tanks has plenty of room to expand. The piping between the tanks and the drain valves are the main place there to be wary of, and they do get empty--or close enough to call it empty for any practical purpose--with a good drain.
A cup or so down each drains is sufficient. A gallon down each drain is overkill. It won't harm anything, but it's unnecessary extravagance.
โOct-28-2019 10:43 AM
โOct-28-2019 07:39 AM
JaxDad wrote:
Just out of curiosity though, all my sinks go into my grey water tank. How many extra gallons are you saying should be poured down the toilet to protect the black tank?
โOct-28-2019 06:02 AM
โOct-28-2019 05:23 AM
โOct-28-2019 04:45 AM
suprz wrote:DrewE wrote:suprz wrote:
Use compressed air and blow the lines out, (make sure all faucets are open, and air is regulated to 30lbs psi, no need to get crazy) have hot water heater open, via anode rod or drain plug, THEN, pump RV antifreeze in like usual. Don't forget tank flushes and outside shower too. open faucets to relieve pressure once finished. And at least a gallon down each drain, and the toilet.
โOct-28-2019 02:46 AM
โOct-28-2019 02:38 AM
โOct-27-2019 06:04 PM
โOct-27-2019 01:21 PM
โOct-27-2019 11:20 AM
jseyfert3 wrote:dougrainer wrote:
1. RV antifreeze is REQUIRED if you have a AquaHot type system. Blowing out is not enough per Aqua Hot.
2. RV antifreeze is NOT a good idea for Icemaker molds. Kind of leaves a slime and takes a good flush and cleaning out to remove it.
3. RV antifreeze is REQUIRED to be installed in P traps. You have to have something in there to prevent freezing
4. propylene based or regular RV antifreeze--- makes no difference.
5. Gravity draining is NOT a good way to drain. I like it tho. It makes me good money in the spring when the people that gravity drain have those frozen broken parts.
6. Gravity draining will NOT get rid of the water in the Black Tank Flush Check valve
7. Gravity draining will NOT get rid of the water in the Water solenoids of Icemakers(RV or Residential) and Water thru the door solenoids.
8. Gravity draining will not get rid of the water in various types of onboard water filters and their housings.
9. AS others have noted, Gravity does not get rid of water in a standard RV toilet water valve
10. Gravity draining will NOT get rid of water in the solenoid of a Macerator toilet or its Macerator Pump
11. Gravity draining will not get rid of the water in an external Macerator drain pump.
LAST, do what you want. If you do not do it correctly, you either pay for new parts or pay ME to replace the parts with Labor and cost of parts. Doug
Well, I will continue to gravity drain, as except for the toilet (which I learned the hard way), I had no issues gravity draining. Probably because except for the toilet I have none of the things you say gravity draining won't get rid of water. ๐ (and the main water filter, but you have to remove that even if doing an anti-freeze flush, so it doesn't really count)
Suppose it wouldn't be hard to do a compressed air flush though, especially as I already own a compressor so I'd just need some adapters. That would ensure everything was good, and if I remember the toilet manual correctly you can do a compressed air flush and not have to disconnect the line or run antifreeze. I'll double check that before winter gets here. I'm certainly not going to do an anti-freeze flush as we plan on camping at least once a month through the winter, with water. Not going to put anti-freeze in the water system and flush it out every month for 5 months!
