โMay-04-2015 08:03 AM
โMay-09-2015 08:52 AM
grizzzman wrote:jrnymn7 wrote:
RE; IUI charging:
http://www.mpoweruk.com/chargers.htm
Scroll down about a third of the page. Article is dated 2005.
Is that to be considered "recent"? Not sure. All I know is "multi-stage charging" has been around a lot longer than I've been RV'ing. I admit I am not at all familiar with linear type chargers, or single voltage chargers, but I can't imagine flooded lead acid battery technology has changed a whole lot.
Anyway, I doubt any of this has to do with establishing proper charging voltages. All I know is what I've seen first hand. I do not cycle my bank deeply, nor do I let it sit in a discharged state or any real length of time. But I am seeing the effects of regular over-charging. Self discharge has increased by leaps and bounds, and resting ocv's have dropped noticeably. I doubt anyone recommending I charge at 15.3v on a regular basis is going to reach deep into their pockets and cough up the near $700 to replace my bank.
Sorry that was a copy and paste. I agree IUI charging has been around for a while. The reason i even brought up IUI charging is because of the OP interstate battery charging profile. I was able to get a hold of a upper level tech and he admitted that they screwed up there IUI recommended charging profile. But i talked to a lower level tech and he was convenced that the profile was correct. I find it intrusting that Rolls , Fullriver , US battery , GMB and others provide charging profiles for IUI charging. I use this charging at work and my RV and has worked well for me. Sorry to here about your batteries. O and MEX the batteries in question ARE hybred antimony pos calcium neg cunstructed batteries.
โMay-09-2015 08:50 AM
jrnymn7 wrote:
RE; IUI charging:
โMay-07-2015 12:39 PM
โMay-07-2015 12:21 PM
โMay-07-2015 11:56 AM
โMay-07-2015 11:38 AM
โMay-07-2015 10:51 AM
โMay-07-2015 10:34 AM
โMay-07-2015 10:05 AM
โMay-07-2015 09:26 AM
grizzzman wrote:
IUI Charging
This is a recently developed charging profile used for fast charging standard flooded lead acid batteries from particular manufacturers. It is not suitable for all lead acid batteries. Initially the battery is charged at a constant (I) rate until the cell voltage reaches a preset value - normally a voltage near to that at which gassing occurs. This first part of the charging cycle is known as the bulk charge phase. When the preset voltage has been reached, the charger switches into the constant voltage (U) phase and the current drawn by the battery will gradually drop until it reaches another preset level. This second part of the cycle completes the normal charging of the battery at a slowly diminishing rate. Finally the charger switches again into the constant current mode (I) and the voltage continues to rise up to a new higher preset limit when the charger is switched off. This last phase is used to equalize the charge on the individual cells in the battery to maximize battery life.
โMay-07-2015 09:24 AM
โMay-07-2015 09:05 AM
โMay-07-2015 08:54 AM
โMay-07-2015 08:28 AM
MEXICOWANDERER wrote:
These so called "battery experts" are crazier than a s---house rat. From one extreme to the other they veer and wander. Lost little children trying to find their way. Man this is even worse when I had the company. I guess no one wants to represent electro-chemical reality anymore. "Oh! Charge at no higher than 14.4 volts! No wait a minute! 15.3! No! Nothing is correct! Where did I put the cyanide supplement pills?"
Ever heard the term "Fart In A Whirlwind"
It's when you allow ignorant people to do your thinking for you.
There is enough VALID informatiin on this site to educate a novice more thoroughly than what 80% battery peddlers will EVER know. If you choose to ignore valid information please weep in silence. The whirring funnel cloud noise of utter confusion is distracting.
Hey my car is not starting up fast every morning. Quick! Call the salesman - he'll know what to fix. Only MANUFACTURERS can properly represent proper battery care. Not Interstate, sears, Kragens, Wal-Mart or Dairy Queen. Interstate is a battery merchandiser. They are experts in warehousing, distribution and stocking batteries from whatever manufacturer they can strike a deal with. Imdividual distributors are FRANCHISES just like McDonalds and the corner Chevron station. I've met a few distributors who knew their product enough to offer decent service. Then I've met others who were dumber than a freshly dried mud pie. They managed their business well and rotated stock and kept good books but their knowledge of batteries was pathetic. Same issue for Sears Roebuck. A guy comes swaggering out with an impedence meter and proceeds to heap enough B.S. onto a question to properly fertilize the eastern half of the county park.
Some of you need to get whacked over the head with a baseball bat to get your attention?
If you do not trust the -correct- information on this forum TELEPHONE THE BATTERY MANUFACTURER. They have people called application engineers whom are a lot more savvy than a battery peddler.
Yes 15.3 volts absorbsion is too high except for Fargo North Dakota in January. 14.8 volts to 15.3 volts is half a volt too high. Even .2 volts greater than Top Charging limit.
Sometimes I think my time spent here is reaching too few people. Grumble Snivel
