riven1950
Jun 03, 2014Explorer
Mine was hard wired to 12 volts. You can remove the unit, 2 screws I think, and then just disconnect wires till you get a new one. Then reverse procedure to install the new one. Good luck
PS: might want to check your fire alarm and co detector too!
