Itinerant1
Jul 09, 2021Explorer
I've watched Ray from "Love your rv" on YouTube awhile ago showing/ using the LIon Safari battery, it looked like a decent battery with a bms protecting the battery. If you haven't seen his channel using the Safari batteries check it out.
Once you have your system dailed in to your liking, lfp batteries really are a set it and forget battery. I'm a fulltime rv'er that mostly boondocks that use lfp everyday for over 5 years now with solar as my charger 99% of the time, even if I'm on pedestal power.
I have 2 displays, 1 for the Magnum equipment and 1 for the GBS system, that is where I get the #s in my recorded data. The flat voltage of lfp is nice and as you might have noticed ability to still use high draw appliances at low SOC is nice, plus having the option to use lfp in a PSOC fo long periods with the occasional full charge to reset or resynce your capacity meter to the batteries.
