bobvila's avatar
bobvila
San-T-Flush outside inlet broken
Hello,
My San-T-Flush port is broken and there water leaking outside, when I used.
Looks easy to remplace. I strugle to find out in Canada the same part. I checked in You-Tube and found-out that some user replace the San-T-Flush by a City water port.
Should I consider this?
Thanks!!
Attached are outside and inside San-T-Flush
  • I'm with bid_time on this one. Do you really want to take a chance of contents of a full the black tank sloshing up the tube and greeting you when you remove the cap?
    • bobvila's avatar
      bobvila
      This is a outside Sani Flush plug. We connect the plug with a hose water in order to spray water in the black water tank. Did the replacement yesterday and works fine. They only think I did in extra is I removed the check valve of the Inlet water plug. So when I unplug the hose, the remaining go outside as my initial San-T flush
  • Sure, use whatever works. Label the new port as a sani-flush on the camper if necessary.
    • bobvila's avatar
      bobvila
      Thanks! I did the remplacement and removed also the check valve.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
