bighatnohorse
Jul 03, 2018Explorer II
What you are describing is an issue typically seen with the "Schwintek" type of slide.
If your trailer slide is a Schwintek then check this post: https://www.eaglecapowners.com/owners/showthread.php?tid=335
The "one corner" doesn't pull tight issue is common to Schwintek and the fix can be accomplished by the previous poster's suggestion or through other methods - none of which are easy.
