Dutch_12078
Dec 17, 2021Explorer II
I've installed and used a SeeLevel II tank level monitoring system on each of the three motorhomes we've owned since 2005. The reliability and accuracy of the percentage readings is far superior to the "Empty,1/3,2/3,Full" KIB type systems common to many RV's. The external sensors don't get clogged up or coated with anything to cause misreadings as the "screw through the tank wall" sensors can. Being able to reuse the original wiring when installing the sensors and display makes the job relatively easy as long as there's ready access to the tank walls.
![](https://i.imgur.com/n3VKYI0l.jpg)
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
