ericsmith32
Mar 16, 2014Explorer
Shurflo water pump leaking
My Shurflo classic has sprung a leak, I may of cleared out the antifreeze to quick. It's coming from between the very front piece which is the on/off switch. Inside is the pieces in the second pic. Anyone experience in this fix? I can get the rebuild kit but not sure if water should be even making it that far. I'm right next to PPL motorhomes in Houston if I need anything.
