SJ-Chris's avatar
SJ-Chris
Jul 29, 2022
Side door latch/lock won't close without assist...
On my 2013 23' Coachman Leprechaun 210QB, the side door lock/latch has developed a problem. It is a TriMark brand lock assembly. Here is a photo:
The correct operation of "closing the door" is to simply push (or pull) it shut and then it self latches closed (but not locked). Recently, when I did that (pushed it shut) it didn't automatically latch and instead it "rejected" the attempt. Imagine if you accidentally had the deadbolt in the lock position (extended) while the door was open, and then you pushed/slammed the door shut. It would make a loud "thud" and sort of bounce back open because it cannot possible close with the deadbolt sticking out. That is sort of what it is like, however it isn't the deadbolt causing the issue, it is the springy door latch part (circled in red in the photo) that is supposed to compress and then latch when the door closes. It is as if the springy part is extended out a little too far and then when the door tries to close it catches on the flat part of the springy part and not the slanted part of the springy part (which would then force it to spring inward and allow the door to close).
LOL....yes I realize "springy part" is obviously not the right name for that part. It is the part that (with the door open) you can push it in and then it will spring back once you remove the tension. It is similar to most standard door latches in your home. It's this part:
So....who here has had a similar problem? Is it possible/easy to open up the Trimark lock assembly and make some sort of adjustment? Thought I'd ask here first to see if anyone has any experience with these.
Thanks!
Chris
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
