D_E_Bishop's avatar
D_E_Bishop
Skylight crack repair
Has anyone here attempted to weld a cracked skylight made of polycarbonate? I finally found a new dome but if I can fix it for a few cents instead of $140 plus shipping for a new dome, it would be worth it.
I have a hot air type welder and the correct rods as I've done repairs on other items. I will drill a stop crack hole first and then weld. One crack is where a mounting screw is located and I'll weld and then install a new screw on either side of the crack.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
