M_GO_BLUE1
May 12, 2013Explorer
SLIDE MOTOR RELAY???
Just pulled into our RV site and one of our slides does not want to go out...
It started about 2 inches then stopped...thought it was the fuse but the fuse is good...BUT IN THE FUSE BOX ARE RED LIGHTS BELOW EACH FUSE AND WHEN YOU PUSH THE BUTTON IT CLICKS AND THE RED LIGHT IS ON UNDER THE FUSE FOR THE SLIDE MOTOR
Is the the relay or what?
Also the slide covers one of my four vents for the furnace...can I still run the furnace?
ANY IDEAS OR SUGGESTIONS ARE WELCOME...
