fordman13's avatar
fordman13
Slide out help.
1998 holiday rambler 5th wheel. 2 sides. The main slide will extend fine but it will not come back in, it has a dewald pump. Only way to get it to come back in is to swap the two hose, then it will come in like normal, but won’t extend. Motor/pump runs but sounds like it’s bypass on the direction that won’t come back in.
Done a bypass check on cylinders both are good with 0 bypass.
Inspected the manifold block, along with the 2 stem/directional valves and the pressure reliefs valves
Swapped stem valve with the one slide in the bed room with no change. Swapped coils for the valves, no change. As well as the pressure reliefs.
Need help. I’m out of options.
  • wa8yxm's avatar
    wa8yxm
    I see you eliminated the valves and colis
    That leaves the controller and the switch
    NOW: The switch.
    Remove all 12 volts. you want NO POWER to the switch
    (Alternative disconnect the swtich but it's often easdier to lift the negative battery lead)
    Operate the switch both in and out 50-100 times just back and forth.
    Restore power and see what happens.
    Believe it or not this has worked for me on another system.
    NOW: If it works you need to make a decision:
    1: Buy lotto tickets cause when you hot, you hot.
    2: Not buy lotto tickets cause you have used up your weekly allotment of LUCK.
  • I guess it could be a bad hose. From my experience with hyd. Over 20 yrs. I’ve neve found a bad hose.
  • Bad hose ?
    On the retract side
    You know it retracts when you swap hoses
    And use the out hose to pull the slide in
  • I swapped valves, out from the bedroom side. It didn’t make a difference. Check and swapped both coils. No difference
  • wa8yxm's avatar
    wa8yxm
    The suspect list and it's short.
    1: Dirty switch. YES the control switch may be dirty. If this is NOT the case the pump will run but no movement.
    2: failed valve or valve magnet (Solenoid)
    Now to test the valve you need a flat piece of metal NOT SHARP which a magnet attracts (Test) a kitchen knife may work well.
    Hold it about 1/8 to 1/4 inch flat to the magnet while someone hits the switch, OBSERVE (A working magnet should attract but a well shielded one may not)
    Observe if possible the valve if it's not enclosed.
    From there on you got to figure out WHY it's not working.
  • Blockage in the manifold
    You swapped coils and valve stems
    Only thing left is a blockage
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
