RognBon's avatar
RognBon
Smoking GFCI outlet
With the engine running I turned on the inverter (Xantrax 2000 watt Freedom 20) and one of the GFCI outlets inside the coach began buzzing and smoking. Turned the inverter off and the smoking stopped. With the generator running and the inverter off, the issue stopped. All 12 volt (lights, etc) are working and all 120 volt outlets are functioning when on generator power. All lights on the inverter panel show normal charging, amps, voltage, etc. Any input as to what the cause may be and what I should look for to correct?
1997 Monaco Dynasty
Cummins 8.3
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
