Jarlaxle
Apr 26, 2021Explorer II
2oldman wrote:
What happens is your converter puts out a higher voltage than the cheaper bulbs can stand. Look for bulbs with a larger voltage range tolerance. I've had leds in my coach for years without burnouts, but I have a DC/DC converter that keeps it all at around 12.8
Any bulb designed for vehicle use should be fine to at least 14 volts.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
