obiwancanoli's avatar
obiwancanoli
Solar charging - can it be so?
I'm still trying to wrap my head around the solar and power issue, but I have learned a lot. In conversation with my RV service tech, an independent guy who takes pride in his knowledge and work, I was listening to him discuss the wiring issue, in conjunction with a new Victron controller (100/50) and Victron 712 Voltmeter he'll be installing this week.
Something my tech said about properly wiring the solar panels - in series, I think - got me to wondering...., rather than the alternative setup, pretty much has a good 5-hour window (10-3) for maximum charging, where in series would allow the panels to begin charging as soon as daylight hits, albeit at a lower rate, of course.
I've always heard that maximum performance of any solar panel was generally limited to the most direct sunlite one can have - about 5 hours. And clouds, trees, buildings, etc., severely reduce their capabilities, if not altogether eliminated them.
Now I'm thinking I heard my tech say that properly wired, panels would recharge batteries as soon as daylight appeared, and through the day until dusk, and I assume he said this knowing a new Voltmeter and MPPT 100/50 Controller (Victron's) would also be installed. He also stated he'd seen solar charge batteries sitting under a flourescent light!
Could it be true?!?!?!
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
