mike-s
Oct 24, 2017Explorer
babock wrote:Most of the Morningstars. Prostar and Prostar MPPT are two in specific. They also have remote temperature sensing.mike-s wrote:I would love to see a controller that has remote voltage sensing. Care to share the info on one?
If the controller has remote voltage sensing, it's mice nuts
Limiting the voltage drop actually does make a huge difference. If you have a length of cable that had a 10% voltage drop at 20A you would likely get half the charge current than you would if you limited it to 1%.If you think that, you think wrong. Come back when you understand how electricity works, including the relationship between voltage, current and power, and Ohm's and Kirchhoff's laws.
