ajriding
Aug 17, 2019Explorer II
Solar Panel Venting
For the flexible flat solar panels how are you venting them (getting air circulation under)?
I previously had mine just taped directly to the roof with Eternabond tape. This worked fine.
The panels really should have air flow under to keep them cooler, and I can feel the ceiling inside hotter under the panels.
My thought is to use corrugated plastic (like yard signs) under the panel so some air flows.
Anyone done this? I don't need opinions, save the thread from clutter, actual real-world experience at this point helps
I also saw someone attach a flat panel with Dicor Lap sealant. I may try this method. The tape method works great but can trap water, not a big deal as my camper is basically a boat hull, but I will leave gaps this time for water to get out, and in :( I could leave gaps with tape, but it is still a mess to remove, where Lap is easy, yet maybe also not as secure… Maybe a combo, tape on the front, lap elsewhere.
I am moving the panel location to the front bulbous part where the black hood is - not enough room so I will take out the super fan and put in a small round 8 inch exhaust fan. The bathroom gets the super fan. Otherwise the panels will be 1 inch tucked under the AC unit, installing it soon.
So, the panels will be near the front of the camper in the wind.
