I like the bottom picture with 4 panels. I have a total of 415 rated watts, and my Tri-Metric would read -120 AH in the morning in January, and I could fill the batteries by sundown.
My RV used 35 Ah daily to run just the CO, propane detectors and refrigerator. The water pump is insignificant, as it can pump 2 GPM for a hour and empty a 120 gallon tank with 7 amp hours.
I liked watching a bunch of TV, and had a direct TV receiver, and ran a 19" tube set. Now I have a flat screen, both used about 80 watts.
I agree that the microwave should be run from a generator, as mine went bad because I ran it on my Trace 1500 watt MSW inverter for about 5 minutes, it never cooked as well on shore power again!
While possible to run the A/C from a 2KW pure sine inverter, it would take about 800 watts of solar to do it! I do not have that much free area on the roof.
SunElec.com they sell aluminum frame solar panels in the $1 - $2 per rated watt price range. Make sure that you are getting panels with a frame, or you will have noplace to mount them.
I cut 6" long 2" angle aluminum (Home Depot) with 3 holes 3/16" for #10 screws into the roof (with rubber roof sealant that helps hold it down, even if the screws where to be removed) and a 5/16" hole for a 1/4-20 bolt into the solar panel frame. A Nylon locknut will discourage any would be theft.
Home Depot also sells grey Romex rated for direct burial, and exposure to sunlight. #10 wire can handle about 12 amps, so if you are running 7 amp panels, I have two on one run, but it would offer less voltage loss to have one panel per wire run. I ran the wires down my refrigerator vent to the controller.
Some MPPT controllers can handle 48 volts (or more) input, so you might be able to string up 4 panels in a row, and the controller can take in 75 - 100 VDC and put out 12 VDC to the battery at much higher amperage. Then one run of #10 wire will handle more than enough amperage.
I would recommend a pair of 20 amp controllers PWM (they are only about $25 - $35 each) and #10 wire connection for each pair of 100 - 150 watt panels). That would probably be a lot less expensive to install than a MPPT controller and less expensive wiring. The money saved could pay for one of those 150 watt panels at a place like SunElec.com
I debated a lot about installing the Trimetric. I ended up buying it because the wife said so. For the cost back in 1997, $375, I would have been able to purchase another 75 watt solar panel. But the wife said so. The Trimetric does not add more amp hours to the battery, just monitors it very accurately. It was nice to know how full the battery actually was. Back in 1999, the 120 watt panels where $429, now it is much less.
So the MPPT controllers are to expensive to be worth the extra 10% in power that they claim to put into the battery. The Trimetric is also a expensive accessory that is not going to add any amp hours.
Good luck!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline waterEscapees.com
