- NoSnowInAZExplorer
bounder39zman wrote:
the spark plug cables go through base to magneto/coil assemblies.
Onan does not offer cables separate from magnetos. Fairly involved procedure to replace, as the engine and mount base must be removed from main base tray, belt and pulley guard removed to access magnetos.
Not difficult, but you have to have someway to lift engine, such as a engine hoist or several very fit friends!
In an emergency, you might be able to splice new sections of cable, but remember these cables carry several thousand volts when firing, so must be insulated very well.
I purchased new Onan cables - their core is stranded metal - the OEM which I need to splice to is fiber. Can the two be spliced?
Thanks! - MEXICOWANDERERExplorerGo to grocery store
To fruits & vegetables
Purchase 3 HABANERO CHILIES, bottles stuff is weak get fresh fruit.
CUT IN HALF wearing gloves is an absolute necessity - oil will burn skin like acid
SMEAR juice on exposed wires and hoses. Squeeze and smear.
If you think Americans are repulsed by white hot chiles, rodents are more so. - bounder39zmanExplorer IIthe spark plug cables go through base to magneto/coil assemblies.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 23, 2025
