jerryspoolman's avatar
Jul 15, 2018
Stainless Steel Screw Standards
I purchased a large quantity of #8 stainless steel screws from BOLT DEPOT, to replace screws in my 14 year old
5th wheel. Most of the original screws had severe rust problems. Even screws that were covered with plastic trim, the heads were
OK, but the tips had rusted down past the threads.
When I tried to use the screws, I had terrible results with the heads stripping out and 1 just snapped. I had only used 5 screws, then
I realized that it would be foolish to replace approximately 300 screws with junk.
The new stainless steel screws could be picked up with a magnet.
Having had good luck with Graingers on other products; I decided I would check their web site. The following is a sample of 2 screws they offer:
Stainless Steel Tapping Sheet Metal Screw
with Pan Head Type and Plain Finish
$23.55 pkg of 50
$14.05 pkg of 100
The first screw is priced at $.47 per screw, while the second screw is priced at $.14 per screw.. The Descriptions are identical and there are others
priced between those two. How can I determine which screw is the proper value?
Any advise would be helpful
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 24, 2025
