- ALL 3 items are thru a relay/solenoid that is activated by the Ignition side of the key switch. That solenoid sends power to the extra fuse panel for those chassis items, It is usually located in the LF outside storage in front of the LF tire. Try turning the Engine on and off a few times waiting about 30 seconds before attempts. Also, IF your coach batteries are dead, those items will not work. Doug
- All those items should be fused from the chassis auxiliary fuse block.
Sounds like an auxiliary relay that powers these items has failed or it's control circuit. Do you have several relays and fuses in compartment below driver's seat?
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 25, 2025
