Feb-02-2018 02:32 PM
Feb-04-2018 01:29 PM
MEXICOWANDERER wrote:
- This would apply to stuff that has tires so I do not feel guilty asking
- First of all incoming water temp would average 45F at the coldest
- This would be an LPG unit
- Must demand water heaters be protected against "the elements"? The piezo ignitor being the issue
- No danger of freezing
- Need enough hot water for shower or dishwashing, not simultaneously
- I've seen several economy models. I am suspicious until proven otherwise
- Lime and scale buildup is a concern. Water harder than a whoopee lady's heart
- We have Bosch heaters
- What is your idea of the recommended Delta T of 70F?
Feb-04-2018 12:10 PM
Feb-04-2018 08:38 AM
Feb-03-2018 11:47 PM
Feb-03-2018 10:17 AM
Feb-02-2018 05:04 PM
drsteve wrote:
We have had a Bosch Aquastar 125000 BTU LP on demand for ten years, and love it. We're on a well, WP is in the 45-60 psi range, roughly 4 gpm delivery. Your supply water is about the same as mine tempwise. No worries there, your tap water will be plenty hot. Don't use faucet flow restrictors, they cause problems with temp fluctuations--these things need a decent flow rate, or the burner throttles back or shuts off.
No idea about the elements, mine lives in the basement.
I use a water softener, and I'm convinced it's the only reason the Aquastar has lasted for over a decade. Lime and scale are the kiss of death.
Feb-02-2018 03:49 PM
