mikestock
Mar 26, 2022Explorer
ScottG wrote:
Inconvenient truth, you have a ground fault.
Start unplugging things until it goes away (fridge, water heater, converter, etc.) and then FIX that item.
Do not circumvent safety or violate codes.
I know you probably haven't been following this. My neighbors are dealing with the same issues when I'm not even hooked up. I have done as you suggested several times over the years and find nothing. I hook everything up and walk away, actually not drawing anything except the inverter/charger. I may be ok for a day or a week but it would eventually trip out. My next-door neighbor in the lot and I watch out for each other. We both have the same problem on the same breaker or on different breakers.
