Snowman9000's avatar
Snowman9000
Strange radio interference situation
I know nothing about RFI, so maybe it's not strange.
I have my MH inside my shop building. It is plugged into a 110v outlet. Plugged into the same outlet is a boom box radio.
When I turn on certain (OEM) 12v LED light fixtures in the RV, I get RFI on AM radio on the boom box out in the shop. Even with the breaker in the RV for the PD converter switched off! So, converter off, but other 110v circuits in the RV would have power available. Nothing running on them, but they have power available. Fridge is off, everything 110v is off.
If I unplug the RV from the shop wall, the RFI goes away, even while leaving the LED lights on in the RV.
I'm not sure if this happened with the previous converter in place, the WFCO.
The PD is grounded to the chassis per instructions. Also, I just installed a Morningstar SureSine inverter. It is set to be always on when the battery switch is on. I could change the DIP switch for that and see what happens. Nothing was running off the inverter, though.
I tried to test the RV radio but inside the metal shop building, unlike the boom box, it won't receive diddly squat on AM.
Explain the RFI please?
