thirteen
Aug 15, 2019Explorer
Suburban DSI water heater won’t light
I went through all the typical troubleshooting. I opened the gas line right st the water heater and it is flowing good and the gas works on the stove and the furnace. Hooked up to electricity the electric element heats up the water. The switch in the RV for the water heater is illuminated. It only works if the 110 breaker is on. I can not find a 12v fuse for the water heater, but I checked all fuses and they all look good. I can’t find another switch for the water heater. I put a multimeter on the 12v wires at the water heater and there is no power.
I just bought this and it is a cheap small RV. 2010 Heartland North Trail FX18. What am I supposed to be looking for here? I can’t figure out why no fuse appears to be for the water heater. I will directly power the water heater to test it, but it seems clear the reason it doesn’t work is that there is no 12v power to it. I have easy access to it so I have easy access to put the multimeter on the wires. 110 power only, no 12v power.
It makes no sense that no 12v fuse appears to be for the water heater.
