goofasap
Sep 03, 2015Explorer
suburban furnace not working
I removed the furnace and had it bench tested at camp world - it tested fine. replaced the analog thermostat with a new one.
when thermostat is set to heat and I increase the thermo to activate the furnace - all I get is a single click from the a/c unit in our living room. I am suspecting the circuit board (located at the ceiling a/c unit inside) may be bad , or a component of it is bad ???
