Here is the solution to your problem. Doug
https://www.rvautoparts.com/520839-Suburban-Mfg-Furnace-Wiring-Harness-For-Suburban-Furnace_p_38029.html?gclid=EAIaIQobChMIhvz435X85gIVUv_jBx2PegdfEAQYAiABEgL3k_D_BwEON THE FURNACES:
521099 CAN REPLACE THE 520741 ON THE FOLLOWING MODELS IF YOU ORDER THE APPROPRIATE WIRE KIT WITH THE 521099 BOARD:
SF20/25/30/35/42; SF20F/25F/30F/35F/42F USE 520832 WIRE KIT
NT24/30/34SP; NT40 USE 520839 WIRE KIT
NT12/16/20S; NT12/16/20SE USE 520840 WIRE KIT
DD17DSI WITH DATE CODES BELOW 9124 USE 520612.
DD17DSIWITH DATE CODES ABOVE 9124 USE 520741.
