Lemonhead78's avatar
Lemonhead78
Suburban hot water heater threads
My water heater has only been used for one season. The anode rod was pretty bad so I ordered the replacement. I noticed the threads in the tank were nasty looking. And when I put the new rod in , it didn't want to go that far. I hope I didn't damage the threads. I can't test it for leaks for another month because it's winterized right now and the suspense is killing me. So in the meantime I've seen 2 separate articles saying I should buy a 3/4inch npt thread chaser ( different from a thread tap ) . This will clean the threads out ( as long as I didn't damage them ) . The thing is I'm pretty sure this size chaser Dosent exist. I searched amazon, checked Home Depot and even a plumbing supply store. Can anyone give me any advice on this . It would be greatly appreciated.
The reason I may have damaged threads is because the weight of the anode rod made it really awkward pitting the plug in correctly. I'm hopeing threads weren't damaged and it got tight from the build up on the threads not from crossing.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
