Old-Biscuit
Feb 21, 2018Explorer III
Bill.Satellite wrote:
Why is it not a sign of a bad valve. If air can't get in, suction is created and the water won't drain out. You removing the valve makes it work properly. Sure sounds like a bad valve to me.
X2
If galley tank drains OK when dumping then roof vent is clear
So that leaves the AAV NOT opening which then makes sink draining slow
