SJ-Chris's avatar
SJ-Chris
Dec 06, 2022
Suggestions for using "wasted" solar power?
Looking for suggestions...
How would you use ~150-250w of power for 8-10hrs per day so it's not just "wasted"?
I've got multiple RVs (Class C) and they each have 500w of solar panels, and 200AH of lead batteries. Most of the time, especially in the off-season, they are just sitting in uncovered storage (getting plenty of sunlight year-round). While in storage, the solar is on and the batteries are easily maintained at 100% by the solar (my RV standby draw with everything "off" is only about 0.3amps). The output from the solar charge controller goes to my batteries and a 2000w PSW inverter (which is always off unless needed while camping as it draws ~2amps in standby when on). The solar charge controller also has terminals for a load (pos/neg) such that the solar charge controller could power something else (in addition to maintaining the coach batteries) while it is collecting sunlight.
In order to maintain the coach batteries at 100% it probably only uses ~20w worth of the 500w of solar. Of course we all know it is next to impossible to actually get 500w out of 500w worth of solar panels, especially in the off-season. But certainly my 500w worth of panels must be generating 200-350w worth of power during off-season sunlight hours (I live in CA so most days even in winter are sunny).
It got me to thinking the other day... It sure would be nice if that "extra" solar power (not battery power) could be actually DOING something instead of just holding the batteries fully charged WHILE IN STORAGE. There is a load terminal (pos/neg) coming off the solar charge controller and I'm thinking about getting an inexpensive 300w inverter to connect to it. My understanding is it would only have power when it is coming from the solar panels, and NOT getting power from the batteries. So it is a way to harvest/use this "extra" solar power from my panels for probably 8-10hrs per day. The question then becomes, "What to do with this power?"
The RVs are not stored near my home, so there is no way to use the power on my home.
A couple ideas that come to mind, but just not sure if they are needed/worthwhile...
- Power a circulating fan. This would move air around in the RV to hopefully keep things fresh and dry. Not sure it is needed though (I haven't had any problems with smells, mold).
- Power a humidifier. This might help to keep moisture down inside the RV. I haven't had a problem with this, but seems like it couldn't hurt.
- Power a couple Ultrasonic pest (mice/rat/squirrel) plug-in repellents. I haven't had an issue with mice/rats/squirrel, but prevention is always a good idea. I did have one mouse about 3 years ago. Thankfully, there are a few outdoor cats near where I store my RVs.
Any suggestions on how you would use ~150-250w of power for 8-10hrs per day so it's not just "wasted"? Thought some of you might have some creative ideas.
Thanks!
Chris
