- MP_soldierExplorer
wa8yxm wrote:
Dick_B wrote:
After giving it three seconds thought might one want to bypass the heater to work on it or replace it while still living in the RV?
I've never looked at it but is there a drain? And I really like Dick's answer.
Many commercial installs have bypass valves even though they are designed to NEVER be shut off,, For just that reason.
Nope, no drain. It's tankless. - 1. They may just have the bypass system despite what model water heater
2. Girards do not have a drain
3. Yes, you have to blow them out and add antifreeze to winterize, but, maybe you do want to use the water system and not have to worry about the water heater after winterizing. Easier to then drain and winterize without blowing out the Water heater again and adding the antifreeze. Doug - wa8yxmExplorer III
Many commercial installs have bypass valves even though they are designed to NEVER be shut off,, For just that reason. - kedanieExplorer IIOr perhaps using the RV water system in freezing conditions and no hot water is desired?
Keith - Old-BiscuitExplorer III
Ding, Ding, Ding...... - Dick_BExplorerAfter giving it three seconds thought might one want to bypass the heater to work on it or replace it while still living in the RV?
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 25, 2025
