BFL13's avatar
BFL13
Jun 22, 2013
Test Method PWM vs MPPT ?
I might get a chance to compare MPPT with my PWM on the set of two 100w panels. I get 12.6 (Isc) now with PWM so that is the "standard"
I was thinking of a quick connect set-up to swap controllers in place, and also to run the two 100s as 12v like now and as a 24v in series.
I gather MPPT does better on lower battery voltage. Does having a loaded voltage on the battery work for that same as if the SOC were lower? If so I could do two voltages, one low one higher on each test. Or?
Is it ok to swap controllers in place? I might have voltage drop that has no effect on the PWM but might bother the MPPT, no idea.
Any suggestions on how to do a quickie test (of course with no clouds that day, and do it mid-day, etc etc.)?
I have no idea how to test for the (bogus?) claim that MPPT will have a greater percentage gain in the shoulder hours. If there is an easy test for that I could do that I suppose (have Trimetric)
Not clear yet whether I will get the chance but hints of it. (borrowing the MPPT) Want to be ready ahead of time so can prepare a test set-up that is fair. (Otherwise, those MPPT guys will moan and whine :) )
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
