JiminDenver's avatar
JiminDenver
Dec 07, 2013
The second Eco-worthy MPPT came today.
I was messing around with the auctions for the Eco-W last week and found the auctions with free shipping go for between $80 and $90. Since one auction I was in was finishing up last Saturday while I was online, I made the last bid and got one for $86.
I was going to buy it from a seller with US stock for $115 so that it would get here quicker but I don't need it till spring so the extra will pay for the wires, etc. Funny thing is that it got here in 6 days from China. I was shocked as the first one took a month.
Now for the wire. There was a thread on this wire a while back but I don't remember the outcome. I have the MC4 connectors needed, just wondering if I should go with the same 10G solar cables I'm using with the first controller.
This is the wire, 100 ft of 10 AWG gauge zip speaker wire.
click
Thank you
  • Probably won't apply, but a lesson from one of my set-ups last summer using two 20a controllers:
    You can save wire going from array-controller by, instead of running two separate long wires all the way to two controllers, you parallel the two arrays near them, run one fatter wire over to the trailer, then put a Y in the fat wire and go to each controller from the Y keeping each leg the same as possible.
    Each controller won't do exactly the same amps as would be ideal, but their total amps comes out the same as running two separate long wires all the way.
  • Thank you BFL, I think I'll skip the lugs then.
    I agree with the versatility of the two systems and redundancy. I went with two Eco-w so that they would match up when both were on one bank. I'll test that theory as soon as I get the rest of the gear needed. I bet 30a will push that big ol 8-D around better than 12a did.
  • On the EcoW terminals, I found the screw down on top part too small but was able to shove #8 in the holes underneath the terminals and the screw goes down there far enough to hold the #8 in place and gives good contact to the underside of the terminal.
    The #8 wires are about 18-24 inches long and end in clamps (50a type bigger ones that will clamp on my copper pipe extensions from the battery pos and from the Trimetric shunt.
    I use the clamps so I can swap over to my other battery bank with some extra wire and give it some of that fine EcoW if ever my RJ special quits. I have the same thing on the RJ special (this time via #10 pigtails) so I could use the RJ special over to the other bank if the EcoW quits. I can also put both controllers to work on any one of the banks. I like redundancy and max flex.
  • BFL
    What are you using as a connector for the run to the batteries? I bought lugs for 4 awg but will have to rework them to fit in the slots on the controller.
    BTW
    I think I know why it got here so fast. The return address is in Ca, not China. So it must be shipping from there as it shipped on the 3rd and I had it the 6th.
  • We are out only a week or two at a time but even then, if I'll need to replace it in time, it is money down the drain now. I'll look for a better option or just go with the solar cables I'm using on the first system. Twice as expensive but will last.
    Thank you for the replies.
  • Zip cord is likely to degrade with UV exposure and become brittle. How fast?? don't know. And heat will make it brittle also. So.... it may not be the best choice even if it is free.
  • JiminDenver wrote:
    Good idea Ken but know these are portable panels. I'd replace the panels for a matched set if I ever mounted them and go with more suitable wire too.
    Then you probably want a UV stable insulation.
    Here is a link showing the properties Wire Insulation Properties
    EDIT: Here is a better pdf Download
  • Good idea Ken but know these are portable panels. I'd replace the panels for a matched set if I ever mounted them and go with more suitable wire too.
  • Jim, I would ask them what the insulation specification/rating is since that determines where it can be installed safely.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
