MEXICOWANDERER's avatar
May 21, 2014
This Is Plan For My Own Battery CHARGER
AMMO CAN
BATTERY CHARGING SYSTEM
Switch type power supplies have made transformer battery chargers obsolete. The new power supplies are so small, and less heat producing it is possible to stuff a lot of power supplies, DC to DC converters, fans, timers, switches and voltage adjusting rheostats into a War Surplus 40 mm ammunition box. Heavy gauge steel.
I decided to produce a charger with a maximum charging potential of 60 amperes. The unit has a “do-all” timer. A 12-hour spring wound timer which is bulletproof, and easy and fast to operate. But the timer does not control one feature – a battery maintenance charger which is set to 13.4 volts and has a potential up to 10-amperes of charging at that voltage. When charging, or equalization is terminated the Ammo Can automatically defaults to battery maintenance charging.
A good battery charger has an equalization system built-in, that observes the Battery Council International (BCI) recommendation for constant amperage charging at exactly 5% of total battery ampere hour capacity. The Ammo Can Charger, provides constant 5 amperes charge rate limited to 16 volts, for group 24 and 27 batteries and another system to provide 11 amperes voltage limited to 8 volts for a single GC 220 golf car battery. The functions are switch selectable and time controlled with the 12-hour timer. A surplus rainproof generator control panel with hinged transparent Lexan lid was modified to allow placement of the 12-hour timer, switches, and digital voltmeters (2) and ammeter.
How Is This Accomplished?
2-33 ampere Meanwell power supplies are utilized. The power supplies are isolated by a Shottky 300 ampere rectifier pair. One 200-watt DC-to-DC boost converter feeds a constant amperage control circuit for 12-volt equalization. One buck DC to DC converter feeds a 2nd constant amperage control circuit. The boost converter is set at 16.0 volts, the buck converter is set at 8.0 volts, the 1st amperage control circuit (for 12 volt batteries) is limited to 5.0 amperes, constant – the 2nd amperage control is placed after the buck converter and limits 8 volt current to 11 amperes.
A shunt monitors amperage as voltage enters the positive battery charging cable. Voltage is monitored at this point as well. Both measuring devices are not closed loop but rather fed 5.0 volts from yet another power supply (a TO-220 regulator on a heat sink). The meters are fed by the battery maintenance charging circuit.
A pair of 50 mm ball-bearing 33 db 12-volt fans control ventilation. One fan takes air from exterior, the second fan takes air from the interior of the Ammo Can case.
Control is extremely simple. The Intermatic spring-wound 12-hour timer, is also the on-off switch except for the maintenance charger. 1 on/on switch chooses one or both power supplies. Two 50-amp power switch controls output to both of the power supplies. When power is switched off at both 50-amp switches (they are ganged like a house 240 volt circuit breaker), it serves as a control signal to a SPDT Tyco relay. The relay switches off. Remember, the main power is isolated by the Shottky rectifiers. Power can not “feed back”. The only power circuit running through the Tyco relay is through the NO contacts – please do not confuse this with the relay's control circuit. When power to the relay coil stops, the relay switches to the NC contacts. The power now flowing through the NC contacts is the main power feed for both buck and boost DC to DC converters. Another DPDT on/on switch chooses boost for 12-volt equalization or buck for 6-volt equalization. The current limiting devices follow in the circuit after the buck and boost converters so no selection or control is warranted. Both voltages and current are controlled.
It may sound complicated but this is how the Ammo Can Charger operates...
For regular charging select timer spring control up to 12-hours of operation, after insuring both 50-amp rated switches are switched to “on” to allow full 60-amp charging potential. The digital voltmeter and ammeter allow precise resolution of event as they are occurring.
Battery equalization. Select timer spring control up to 12-hours of operation. Switch off both 50-amp rated toggle switches, select on/on switch to direct power to either the 16 volt or 8 volt equalization circuit. Remember, equalization current is constant meaning it is controlled appropriately. The digital voltmeter and ammeter allow precise resolution of event values as they are occurring
Protection circuits. One pushbutton 15-ampere breaker. The equalization circuits, both of them are protected by the Tyco relay against feedback voltage when either of the main Meanwell power supplies are in operation. The Shottky rectifiers isolate and protect the Meanwell power supplies. The maintenance charger is isolated/protected by it's own Shottky rectifier in it's output circuit.
In the event of a power failure, the spring-wound timer continues to count down and shuts off in a normal manner.
The battery maintenance charger is protected by it's own Shottky rectifier, which is rated at 200% of maintenance charger maximum potential.
To clarify, when the Ammo Can charger is plugged into AC power, the maintenance charger is working. No switches control the maintenance charger. The maintenance charger output power however does pass through the ammeter shunt. The maintenance charger also powers the 5 volt power supply, which powers the ammeter and voltmeter. When the meters are lit the Ammo Can charger has power. Plug in the Ammo Can charger and the meters light up. You are wondering about the fans. 12-volt power from the maintenance charger powers both fans.
The Ammo Can charger has a maximum draw potential of one or two microamperes if it is connected to a battery, and AC power is interrupted. Therefore feedback “power bleed” is infinitesimal.
The Ammo Can Charger Is Not Financially Feasible To Manucture For Retail Sale
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
