Naio
Aug 25, 2016Explorer II
MEXICOWANDERER wrote:
The cost for filling one gallon jugs is double that of the 2.5 gallon which itself is 70% of the 20 liter jugs. I just dislike the idea of paying eqvt of 33 cents a gallon for water. $3.30 for ten gallons.
Are all jugs the same when it comes to the amount of water the spout dribbles? Sounds like there is more variety available these days.
Once the jugs are lined up on the shelf, I can avoid dealing with the weight. The water guys sticks the jugs in the car and my housekeeper unloads them and sets them on the shelf. But when tipping the bottles, they want to get unruly and slip and twist. That's where things go wrong.
Tried to look up SoundGuy's recommendation - ends up multiple 404 cannot connect.
Being disabled is expensive :(. But your back may be worth 33 cents, even x 10,000.
Are you tilting the big jugs to get water out? Why not get the kind with the spout at the bottom, if you are going to use big ones on a shelf?
