ernie1's avatar
ernie1
Tire tread squirm
Had two new Toyo Open Country tires installed on the back of my 2005 PleasureWay Excel the other day and hit the road after the installation. I immediately noticed a real squirrely handling and the vehicle was all over the road in the wind, changing lanes and braking. Very long story short and a couple of tire changes later, now that I have about 500 miles on these new tires, the problem seems to have gone away.
With a little research, I now know that tall tires with a deep knobby tread that are installed on the back end of a vehicle with used tires on the front are more prone to this condition. Lower profile tires may not do this. Anybody else ever experience this?
  • Are the the same brand and size as the ones on the front?
    Even if with replacement with same brand and size, there is a size difference between new and used. Most vehicles that I've had, when doing a single axle replacement of tires, the steering has always been affected (rarely, but even for the better).
  • On my Tundra I switched from P rated tires to BF Goodrich Rugged Terrain
    LT E rated tires. First trip out I thought they were worse than the stock tires but after a hundred miles or so they apparently settled in and became rock solid stable. Hope yours are just taking a little longer.
  • Yes...lots of times. I think the 85 series tires showed more tread squirm than say a 70 series tire.
    When I was on the road I turned over two sets a year on my one ton DRW trucks. That type of work required a AS or a mild AT type tire with the deepest tread I could find which were usually in the 14/32" to 16/32" range. Boy were some of those tires squirrelly the first few hundred miles. Once they broke in no more tread squirm.
  • Yes, I noticed that too. Also inflated to higher than necessary tire pressure increased that effect on the new tires. Most likely doe to running on the centers and not having a full tire foot print on the ground.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
